1 - 20 of 22 Posts
hello
i have a pair of EVO 7 front brembos in mint condition......i was going to fit these to my 33gtst but not going to bother now as its for sale.....
These will fit any spec 33gtst...you will need the big brake kit from DB power which he sells for around £300 and that includes two 345mm rotors plus lines and mounting bracket.......im looking for £120 posted to UK or NI..SOLD SOLD
I also have a set of new front extended wheel studs (65mm) i think 10 in total....
if you are going to fit spacers above 7mm thick you will need these......£20 posted to UK or NI SOLD SOLD SOLD
Moderator
You can, but with the standard calipers the pads won't be able to act on the full area of the disc. The brembo calipers are designed specifically for the bigger disc so that they can use the entire disc instead of just two thirds of it. They are probably wider too to take wider discs, standard calipers won't take anything more than standard thickness.
Discussion Starter #17
brembos
calipers and wheel studs sold to Johnny A....:)thanks John:)
1 - 20 of 22 Posts
