1 - 3 of 3 Posts
Haboodadi
Guys I'm having some issues with the Radiator Fan for not working (sometimes) when the engine gets hot.
I've tested the Fan, Fuse and the Relay. All are working fine.
I understand that it could be a Sensor issue from the Radiator that is not triggering the Fan, but unfortunately I can't deal with a replacement right now, can't order anything online and won't be able to find any part for this car here.
So I really need help on bypassing the Radiator Fan as this is the only option for me at the moment.
I already have a custom switch installed inside, was for something that I don't use anymore. I just need to confirm on which Sensor (that triggers the Fan) I should be working on to run the wires from and to the switch.
the radiator fan on yours is run off the waterpump unless your thinking of the ac fan?
Do you mean the overheat fan which is in front of the radiator? It's triggered by the sensor at the bottom of the offside side of the radiator.
1 - 3 of 3 Posts
