Does anyone know whats needed exactly to fit Gold Brembos to the rear of my R33GTST? I have the calipers which I'm in the process of refurbing and can get stock discs and pads for just over a ton (322mm discs is that correct?).
But I know people mention mounting bolts for the calipers, do I need the ones off a 350z or can I use the ones from the stock GTST setup? Also is there an issue with the handbrake assembly?
