The longer the Duration of a cam on the exhaust side it will make the car more laggy and come on boost later so make power later.
I'm not sure on the comparison of the GTR duration against the GTS cam.
On the inlet cam you really want the duration and lift as high as poss so more air gets in there.
I've kept to a std GTS exhaust cam and put a Tomei PON cam on the inlet so i make more power but have kept lag to a minimum.
I wouldn't go any lower duration on the exhaust cam as the GTS struggles to flow exhaust gasses as it is.
