The smell of fuel would indicate it's running rich and if there is high o2 then that confirms it, what is the lambda reading? (wideband) Try checking the fuel pressure, as that will have a bearing.
can’t remember what the lambda reading was but it was as it should be. How would I check fuel pressure?The smell of fuel would indicate it's running rich and if there is high o2 then that confirms it, what is the lambda reading? (wideband) Try checking the fuel pressure, as that will have a bearing.
