If im fitting NGK IRIDIUM BKR7EIX plugs, instead of NGK IRIDIUM BKR5EIX which is the recommended plug, could I cause any harm. I understand that these are the same plugs only rated to a higher temp. Is this right.
they will work but tbh most people go for a colder plug than standard not hotter ,as everyone knows you want to reduce engine tempsIf im fitting NGK IRIDIUM BKR7EIX plugs, instead of NGK IRIDIUM BKR5EIX which is the recommended plug, could I cause any harm. I understand that these are the same plugs only rated to a higher temp. Is this right.
yes basicly you put the hotter plugs in those plugs will heat to a higher temp increasing your chance of det not good! the last two cylinders of your engine run hotter than the others two when you take your plugs out you can usaly see by tip colour and det is the biggest killer to most rbsI thought a plugs rating was to do with the temperature that it can withstand not produce. With this train of thought I thought it would be better to go for the BKR7EIX plugs, instead of NGK IRIDIUM BKR5EIX. Am I picking it up wrong.
ssshhhhiittt:bs2: dont listen to me. tbh i didnt even look at the numbers i saw the word hotter and dived inHey Slingo your getting a bit muddled mate.
The higher the number the colder it is NOT hotter.
BKR7EIX are ideal for a mildly-moderatly modified GTS-T and are a good upgrade.
Sharpy DET means detonation.
:slap: Seriously mate. If you are any way unsure then it is best to say nothing or if you think you are right but aren't sure then always state that you're not 100%.ssshhhhiittt:bs2: dont listen to me. tbh i didnt even look at the numbers i saw the word hotter and dived insorry mate
tbh theres no point in posting a maybe or might fit your car post anyway and im sure im speaking for everyone when i say you want to hear from someone with first hand experience,but most of the time i read the post properly sorry again mate:slap: Seriously mate. If you are any way unsure then it is best to say nothing or if you think you are right but aren't sure then always state that you're not 100%.
Better that than causing someone to fit a wrong part and risk damage to their car.
At least you apologised![]()
I believe the gap should be 0.8mm, there is loads of threads on this stuff in here but it take a bit of looking.Also you could ask the supplier you get them from.What are the spark gaps on the BKR7EIX?
ive been looking into getting newones too for a mildly tuned gtst too! are these ideal?
thanks john
As i said, my main point was if you don't know for sure then its best not post at all. However in some cases, i.e. no one else seems to be responding and you think you know the answer then a half idea can at least give give someone an idea of where to start looking, just be sure to make say you are not preaching as gospel.tbh theres no point in posting a maybe or might fit your car post anyway and im sure im speaking for everyone when i say you want to hear from someone with first hand experience,but most of the time i read the post properly sorry again mate![]()
Yes it does, cheers, the plugs ive ordered are BKR5EIX-11, why is the gap bigger on these.:guiness:The adviced stock gap for spark plugs is 1.1mm! But many go for the ones with 0.8mm (in fact it´s 0.76mm) to have better ignition. Simple rule is: Always run the biggest gap, your ignition system can handle without any probs like misfiring etc.
Don´t go for the 7´s when your engine is completely stock mate. You´ll have fouling cause your spark plugs won´t be working in optimum temperature range! You can go one step colder, shouldn´t make too much of difference concerning fouling etc., but not two steps.
So go for BKR5EIX-11 (1.1 gap) or BKR5EIX (0.8 gap) if you want stock heatrange. If you want one colder, go for BKR6EIX-11 or BKR6EIX.
Hope this helps mate! :cheers:
