Dorset/Wilts Area Rep
Front 18x8.5 et 30
Rear 18x9.5 et 40
I realise I may need to get the arches rolled, but I'm intending on fitting wider front wings and 400R arches blended in.
i would say yes if you had the wider front wings on mate as my wheels are 17x9 with a 18 offset and they fit fine on the front and fine on the rear, you may need rear spacers but cant say till you fit them.
Alloy Junkie
Front 18x8.5 et 30
Rear 18x9.5 et 40
Arches Rolled?
I dont think that will be needed unless your car is slammed.
At the front 18x8.5 et30 will sit perfect with the front fender, will look sweet and have no rubbing issues.
Rear: 18x9.5 et40....Its a wee bit weak sauce, if anything you will need a 10mm spacer to help the wheel fill the arch. et40 means the wheel will be further inside the arch, not sticking out. et30 all round is about ideal on an GTS-T ;)
