1 - 10 of 10 Posts
id love to help mate but aint got a clue what your meaning??
T
Guest
Router reset. Take out the power lead for 10 mins. Make a cup of tea to utilise the time and plug it back in. Worked for me, But I was hesitant and forgot the sugar.
Dorset/Wilts Area Rep
Can you check that you Xbox 360 is picking up an IP address from the router, you will need:-
IP
Subnet mask
DNS pri
DNS sec (not always required)
Xbox setting need to be set to dhcp and then run test connection, could be teh firwall inside the router, check waht ports may be required to be open to run xbox live... just a thought
R33
have you logged onto the router to see if its connected to the internet?
go start then run then type cmd then enter
you will then get a command prompt window,
write in ipconfig then enter
this will show you your defualt gateway something like
192.168.0.1 or 10.0.0.1
once you have this number open a web page and put this number into the address bar, this will take you to the routers home page, then get in contact and i will show you what to check......
1 - 10 of 10 Posts
