evening all,
anyone know of a CAS simulator, got some running issues, and need to run the ECU up, checking everything, without the enigne running, I can simulate all other sensors ok, just not the CAS.!
any ideas.?
I would have thought you could simulate the pulse using a signal/function generator if you could get your hands on one. Feedback function generators are dirt cheap on eBay considering how expensive they are new but they're good bits of kit...
yea Ive got crank simulators for common setups, but the skyline, has 6 different size gaps, making it more tricky to simulate......
might end up with a CAS and motor setupo at this rate !! :)
yea, normally its a simple operation to do, on say a 36-1 crank wheel, but the 6 different sizes is a smidge more aqward ! must be summit about..!
