Hello,
I want to know if I need to plumb the Catch can back to the intake pipe.
My reason to ask is because I notice at idle it holds a vacuum. where is that air coming from? is it being taken from the intake pipes via the combustion process?? thereby using some air from the air flow meter?
NOW I have both cam covers going to the can, and the can's other pipe is vented with a little motorbike filter.
would this be confusing the AFM?
Is this a common style of pluming? or for smooth driving and best performance while using a Air Flow Meter should be it be plumed back to the Air Filter pipe..
thank-you
Shaun
Additional info.
Cam covers are bridged via the black middle hose (Rb25 by the way)
1 pipe to the catch can from cam covers.
the oneway valve on the intake side of the engine goes to the Intake plenum via a nipple thing. (Hose Joint)
Catch Can's 2nd hose is vented to atmosphere and a filter.
EDIT sorry, I know this been spoken about so many times before. but I have confusion as to where the one way valve should go if I was to plum back to intake pipe...
thank-you
Shaun
Additional info.
