1 - 20 of 108 Posts
I felt the need to write this up due to people thinking that there is only the one way to plumb in and use a catch tank, first it may help some to have a read of this,
http://www.autoshop101.com/forms/h63.pdf
which will explain the basics to those that don't already know.
Now the whole reason that a lot of people fit a catch tank is to try and eliminate some of the oil that gets drawn
into the intake system and not only lowers the octane rating of the fuel, (which is undesirable on turbocharged
engines) but also gum up throttle bodies, IC pipes and idle valves etc.
Now the PCV system of most turbo engines consists of a part throttle breather which has a one way valve that
is open during idle and off boost conditions, so the vacuum of the engine can draw any oil vapor thats formed
through engine motion and combustion, into the inlet and is burnt in the combustion process.
This valve is usually plumbed into the plenum, and is vented from the cam covers.
Now as soon as there is positive intake pressure (boost) this valve closes to prevent loss of pressure, and a second breather which is also from the cam cover and has no valve, takes over the breathing, but this is
plumbed into the intake before the turbo, so there is useually only a sufficient depression when there is boost pressure
being made.
Hopefully this will give you the general idea of it function, so when it comes to fitting a catch tank, most just
block off the non return valve into the plenum, and then fit an extension pipe to the full throttle breather to the
catch tank, and then leave the other opening vented to atmosphere, which is fine in most cases, and will
achieve the desired effect, however some engines do play up when using this form of venting, but it gets a bit
more involved than i want to go into here.
But there is a second way of achieving the same effect, but still using the factory PCV system with a catch tank,
This basically consists of linking both the full and part throttle breathers together, and running them to the catch tank, then linking the second hose from the tank back to the turbo inlet piping, so the same vacuum is applied through the tank to the cam covers when there is sufficient depression, but in this case the oil vapor is still re emulsified into the tank instead of getting drawn into the intake system, ( it helps to fill the catch tank with stainless scouring pads) to aid oil drop out, and with this method you will tend to see less water accumulation too.
So you see there is more than one way to plumb and use a catch tank.
There is also a way of using the exhaust as a PCV system, which i can go into if anyone is interested.
I will try and find some sutable pics that will show the details.
That'd be a help mate it really would. Are you giving out advice where to plumb into for free also?? If ya dont ask you dont get :D
Good write up Tricky!
Here is a pic showing one way to install a catch can.
My rocker covers and cam belt cover need to be painted :(
Discussion Starter · #6 · (Edited)
Thanks! i have adapted your pic to show what i mean by the closed system, not to good with paint, but hopefully you get the idea. the tank in this pic is rather small and has a breather in place of a lid, and for large single turbo setups i would increase the size of the hoses and tank.
Discussion Starter · #8 · (Edited)
I used open on one of my S14s, but i used the closed on my Supra, never had any oil coming back into the turbo intake, some engines like to have the PCV still running, as it avoids seals weeping etc.
I am currently running a closed system on my 350GT, the VQ engine seems to chuck a lot of oil through the breathing system on idle, it works very well, i would say it reduces the amount of vapor going into the plenum by 95%
You do need to fill or baffle the catch can more on a closed system, long pipework helps too, that way you will see very little oil, if any going back into the intake.
bodged s13.
has anyone used a 'proper' external crankcase breather on the RB (similar to the CA is what i mean) rather than just relying on the block breathing via the head oil drains (which I imagine is a contributing factor to oil starvation in the bottom end at high rpm).
most of the searching i've done just results in a thread saying "if it's breathing that hard, your engine is knackered" which isn't really an answer :D
Discussion Starter · #10 ·
Not sure what you mean by "proper" its a long time since i saw a CA engine so can't remember, i know the SR has an external equalization to the sump from the head, which IMO is why it gets on so well with running an open breather system.
bodged s13.
same thing - it's a baffled takeoff from the crankcase itself that goes to the head externally and then to the PCV/intake.
it just seems to be a bit pants to drain the head and have the engine breathing through the same space.
Discussion Starter · #12 ·
Guess it depends on the available space within the engine design, as to whether an external breather tube is needed, i don't think its necessarily a better design, just a case of needs must.
Discussion Starter · #14 ·
how about the GTR then its setup different to GTSt
In what way does it differ? other than in layout, it still has cam covers vented, and uses the usual part throttle, and full throttle PCV system, so it can be treated the same, its only when higher boost is run from larger turbo/s that its sometimes a good idea to enlarge the std fittings and pipe size.
on the GTR it has one from turbo to cam cover then one linking cam cover together then one from cam cover back to engine ( above injectors )
so which would be the best way on this engine
Discussion Starter · #16 ·
It still has the std configuration of PCV, the pipe from the cam cover to the turbo inlet is whats know as the full throttle breather , and the pipe from cam cover to the plenum is the part throttle breather that has the non return valve in it.
There is no best way as such its really personal choice, but i have heard that the RB26 is prone to heavy breathing problems? is it prone to weeping seals etc? if so i would be inclined to make use of part of the PCV system, and run a catch tank back into the turbo intake, similar to std, that way you retain some of the vacuum effect generated by the intake, which helps stop crankcase pressurization.
Discussion Starter · #18 ·
could you draw on which way you think is best
Have a look at the RB25 pics, the plumbing is the same, however like i said its your choice, which way you go, do you run larger turbo/s or high boost?
Discussion Starter · #20 ·
i will be running steel turbos soon @ 1.2-1.3 Bar
So std with steel exh turbines, 1.3bar is not what i would call high boost;)
I would still say its your choice, if you where running 1.5bar or more i would be inclined to run a closed system, or even Moroso type exhaust evacuation system.
1 - 20 of 108 Posts
