1 - 8 of 8 Posts
Can anyone tell me how to change the front wheel bearings on the R32 Gts-t?
Do they have to be pressed?
Here are some photos. They seem to be getting caught on something. Won't come out.
Thanks for any help.
first of all you need to remove the flange to allow the circlip to be removed and then you can press the bearing out mate :)
the flange is what the wheel bolts to mate that has the large pin type thing going through the middle :)
Discussion Starter · #5 ·
How do the plastic dust covers at the top of the shock arm (holding on the hub) come off without breaking them. What are they called if I need to order them?
Thanks again.
Thanks again.
got a pic mate as im more familier with 33s :)
The R32 one looks very much like the R33 one. ..............I just used a drift to punch out hub from where you are now.
Changed the bearings and used the big nut to pull the hub back in (need to persuade it a little of the way before you engage enough thread)
Hub in the freezer when the wifes not looking worked a treat ;)
1 - 8 of 8 Posts
