i think its around 1.5.
its not hard but i would recomend taking the back exhasut section off and getting one of those plungers from ebay.
Ex Skylineowner
Yup, about 1.5L, think the manuals say 1.8L . Basically up to the filler plug level.
Can do it without removing the exhaust with a universal joint on your socket. A small handpump makes things easier, as does putting your oil bottles in some boiling water before filling. Final tip, make sure you can undo the filler plug before you drain the old oil out. It will likely be fairly stiff.
DIY rating - 2/10 (with exhaust in place- for awkwardness and tight filler plug)
1/10 (with exhaust off)
I couldn't manage to undo the filler cap on mine when I had it on my drive.
So borrowed a friends ramp managed to get the leverage required then then.
Simple job :D I used a funnel and a long piece of tube to fill the oil back in as said 1.5l.
The oil out of mine looked brand new anyway wich pleased me :D
.......P33 TEX.........
does any one know how easy is to replace the gasket on the back on the diff/rear axle? think mine is leaking!! oh no...!
