1 - 20 of 23 Posts
this is me take it or do one....that simple
so bought a bee r rev limiter of some1 of ebay stated its in full working order when removed from car so bought went on holiday and fitted it today to find out that the bloody thing doesnt work correctly took me and a mate ( good with anything electrical) 2 half hours to work it out and it was still wrong...so looked on here for some ifo and found a thread that the fella was having the same problem as i was and it ended up being a faulty unit so i know the 1 ive got is faulty too, so i went on ebay and the assclown doest accept returns so to me this gave it away that he knew it was faulty when advertised so now ive opend a case againts the seller and will now get my money back.....
not happy was excited like a kid in a cake shop to get it fitted....
if you payed through paypal and it was advertised as in full working order you should get it back if you open a dispute
yep paid via paypal... mate so hopefully will get it back and buy new
At home playing with myself!!!
I think you have to wait so many days to open a dispute so keep calm and make sure you copy the advert any any other info that he gave saying it was working correctly.
is the guy on here?
is the guy on here?
havent got a clue pal i was gutted it didnt work really was so looking forward to come home from eygpt to get it done..
Anglian Area Rep
*******s mate. Hence the reason I used to buy all my parts on here or from the traders on here :)
Hope you get it sorted but think it takes a month.
Pm tossef on here as I believe he's a whizz with fitting this sorta stuff.
Not saying you and your mate have done incorrectly but worth asking the question to a man in the know buddy.
are you sure you have fitted it right as the original guide on here is slightly wrong.
Discussion Starter #8 (Edited)
well my mates a wizard with electrics mate but he fitted another to my mates R33 and was done in 5 mins and it was totally working fine.... cant seem to find the member tossef
the guide the got was off driftworks as i couldnt find 1 off here but if there is good guide i dont mind trying again...
Originally Posted by Matt_slater
As some folk may have seen from my other post, I fitted my Bee R but the bloody thing won't work. I fitted it according to the supplied instructions.
Pin 41 Yellow, pin 42 green, pin 49 red and pin 50 black.
The gain is set to 8. Rev 1 to 2500 and rev 2 2500rpm. When reved up with the handbrake on, the Bee R will flash but not cut.
When reved without the handbrake on, nothing, not even a flash.
Has anyone got any ideas?
below is from [email protected]
youve wired it incorrectly..
you dont fit the yellow and green to the pin 42 and 41.. you must go further up the loom. the CAS has only two wires.. it then splits and goes to the ecu as 4 wires.
noow this is what happens to me when its wires up with the gain on 0 its ok car starts up if i switch the gain to 1 it stops the engine if the rev1 and 2 are set to a rev limit it wont go over 2k rpm but my mate isnt sure on the white grey and brown wires as the guide he got off the net says cut 1 for 4 cylinder engine and 6 and antother for rotary he was sure it was brown for 6 cylinder engine but again he wasnt 100% so and ALSO ive got a mines ecu fitted will this be causing any problems as ive still got the starndard ecu upstairs so any advice will be greatly appreactited
just being told that maybe my dash rev guage doesnt work and is intermitting so he says that this could be the problem as it nees to read the revs no is this the problem as the seller contacted me saying that the bee r was in FULL working order when took off the car,
so could me having mis working rev guage on my dash affect this bee r? anyone
Discussion Starter #12
thats whats making me think that this bee r is working corretly so i guessing that if i replace the dash with a working rev guage then it will be fine???
Discussion Starter #14
so u really want to change title of thread to goosed dash rev guage then and retract complaint to seller?
not really buddy never had a bee r so this is a learning curve for me pal, like my mate sed he fitted 1 in 5 mins and worked perfectly. so like my previous question, with my rev gauge not working on my dash will this not make the bee r work correctly? as i was using the aftermarket rev guage the previous owner fitted?
the rev counter feed has to work, but that is from the ecu, as it has to know at what rpm the cut is set to
are all three wire links still intact, as they are a different set up to 4 cyl engines or rotaries etc, the 3 wire loops must still be together, or need soldering back together maybe
maybe a dry joint somewhere also, there isnt much in that box to go wrong
Discussion Starter #16
so do i need to get a new dasg guage that works or can i use feed from the aftermarket rev counter thas being wired in????
sorry if its going on abit but ive never had a bee r fitted so i dnt know where to start..
use the feed thats already there, it feeds from the ecu, as long as that signal is working, it should work fine, are the 3 loops intact?? grey brown and white i think
Discussion Starter #18
no my mate printed off a guide from net and it says split the brown wires?,
but this is what im getting confused about with the dash rev guage with it not working (me thinks its due to the soldering at the rear of the clock) will i need to replace the clock with a working unit b4 i can fit the bee r???
You need to read what was just put and go from what convert just put. Not every guide on the web is correct. Listen to people who have fitted them!
1 - 20 of 23 Posts
