the bit where you put the fluid in will have a bleed nipple on it , get some one sat in the car to press the clutch peddle down, first step is to fit resavior with fluid, get a spanner on the nipple and get your mate to press the clutch peddle down while you upen the bleed nipple, fluid or air will come out while your mate has the pedal pressed down close the nipple then release the peddle, you may have to pull peddle back by hand, mind your eyes when peddle is being pressed as the fluid can squirt out , repeat this about 6 times but make sure you dont run out of fluid as you will have to start again.. hope this helps and it a very easy job once you get going...
