1 - 1 of 1 Posts
Clutch pedal hit the floor and no rebound.
Cylinder fluid was low. Not empty just at minimum. Filled up and no return of the pedal. Have bleed the system 20+ times and still nothing.
I noticed when bleeding the bleeder valve was letting fluid out through the threads.
Also is the tabs on the cap supposed to click under the tabs on the reservoir?
Automotive lighting Motor vehicle Fluid Automotive exterior Bumper
1 - 1 of 1 Posts
