1 - 1 of 1 Posts
Missing His R33 :(
After the blown thermostat, broken thermostat housing, leaking water pump, and the slipping clutch, I've now got the fifth problem in as many months with this damn car.
I recently had a new exedy gtr clutch put in my gtst and all was great for two weeks. Then i noticed a ticking noise from the gearbox at idle with my foot OFF the clutch. If i dipped the clutch a centimetre it stopped, possible release bearing rattling maybe?
This was pissing me off no end, having the car sound like a tractor at traffic lights, but then lady luck shat on my face once again and now my pedal has broken.
I pulled out of a junction, then mid change into second, heard a POP from the pedal and it rushed to the floor and i crunched the gear change.
When i put my foot on the pedal it pushes to the floor with hardly any resistance compared to how stiff it was, and i have to bury it into the firewall to change gear, then the second it lifts up a notch it engages and drives.
I had to finish driving to work like this and then home again. There is no slipping and the clutch seems to disengage fine when in gear. Its just a bugger to get into gear as i can't push the pedal any further down without coming through the bulkhead!!!!
Does this sound like hydraulics or has the pedal box split open???
1 - 1 of 1 Posts
