1 - 8 of 8 Posts
My clutch is going to be replaced also the flywheel has to be skimmed as its all pitted.
So I have decided to upgrade the clutch at the same time.
The only problem is which one to go for?
This is a warranty job so I will probably paying the difference subject to some negotiation with the garage.
Any suggestions as to the type to go for???
Any estimates on the price difference between it and the standard???
Hi Simon,
What do you think you are going to be using the car for ?! Exedy do a good range of clutches from mild to wild. If your going to be doing alot of drag starts I would recomend a sports paddle with uprated cover!!!
Hi Richard
Use? Well I think a few more drag days are in order so the sports paddle with up rated cover might be the way to go.
Any idea of the price?? Of both the standard and the sports clutch.
How does the sport clutch perform when used daily?
I don’t wont to compromise the drivability to much.
Thanks Richard
I am going down to the Garage tomorrow to pick some paperwork up, if they have trouble sousing one Ill be in contact
1 - 8 of 8 Posts
