1 - 2 of 2 Posts
i recently (bout 5 months ago) had a exceedy kevilar racing clutch put in my r33 gtst
but in the last 2 weeks maybe 3 weeks, it has started sliping
its alright in 1st and 2nd gear but soon as i hit 3rd,4th and 5th it slips then it will grip then slip then grip
there is no smell of buring or riding the clutch
any 1 know what could be wrong with it or any information is appreciated
thanks
paul
there could be many reasons really.
contamination of the plate, they do occasionally fail from a defect,
was the flywheel re-faced? has the clutch fluid been changed as it could be holding the pressure plate off the clutch disc,
the way it seems to slip then grip sounds like either a flywheel problem or the clutch disc is damaged or warped though. what ever it is? probably a clutch out job :(
1 - 2 of 2 Posts
