M's Factory
Standard RB25DET
63 cc combustion chamber
413 cc's per cylinder with 86 mm pistons
9 to 1 compression ratio
23 cc for piston dome
6 cc for a 1 mm head gasket
63 - 23 + 6 = 46
413 / 46 = 9 to 1
This should be workable with other engines and also can assist with people requiring to know what compression ratio to work towards when engine building.
so if i got 2mm head gasket for my Rb25 DET to run 1.5bar boost
413/52=7.9 to 1
is that right or am i thick (dont answer that)
M's Factory
:) * cant say a word but nods *
M's Factory
Discussion Starter #5 (Edited)
Do you also want to talk about how far above sea level this affects your boost pressure under your engine under load ?
Ok just to clarify for people the above is a static compression ratio calculator.
If you like mate, all I wanted to know was how do you work out how much to decrease your compression ratio, to enable you to run higher boost. You can ask the audiance, or phone a friend, but fifty/fifty has gone.
M's Factory
OKi doki mate, check this out on my site.
Dynamic Calculator
Unlike the one above which doesnt take into account, Pressure levels of boost, or Elevation in the atmosphere either.
Nice one mush, i will do that for Isaacs engine, so we can work out what size metal head gasket to use for desired boost levels etc. Must say its awfully tempting to put 6 1/2" in the rod size column
M's Factory
:) it does work out quite well this is the calculation device I am using at the moment and have put it on my site so if anyone else needs access to it they can.
I have not linked to it yet hence its invisible unless youhave the link above :) let me know how you get on.
