Hi guys, a while ago I did a compression test and the results were all between 120-135psi.
Since then I have done the timing belt and found the valve timing was out by a tooth, since correcting it I’ve been meaning to find time to do another one. Today I did another one and found all cylinders to be 120-122psi.
I always thought the engine was very tired and on its way out (which it could still be), but do you guys think it’s a possibility that it could have a thicker head gasket to purposely lower the compression?
I appreciate all thoughts,
Ben
Ben
