1 - 1 of 1 Posts
How’s it going everyone. I recently had to replace my radiator because the lip where the intake hose clamps onto was broken and causing me to start overheating. After I replaced the radiator the car wouldn’t start. I ended up replacing my spark plugs,coil packs and coil pack harness. I flushed the oil twice and it came out fine. After a few attempts at starting the car I decided to check the oil again because the oil level was getting low without any evidence of leaking. I drained the oil and it came it milky which mean coolant was mixing in somewhere so I decided to check for a blown head gasket. Upon taking off my intake manifold I saw that one of the pipes was filled with coolant. Every other pipe had just oil without evidence of mixing. Could this be a problem with just the intake manifold or should I just continue tearing the engine apart?
1 - 1 of 1 Posts
