1 - 1 of 1 Posts
Hi people, once again I have a question. I got a second hand crank from a friend that replaced it for his build, it is an R34 crank 05U on the crank and the engine had a spun bearing. I got the crank checked and the machine shop said that they may have to remove .010-.020 on the rod journal and at the same time do all to measure up. They said that the mains are all fine, what I want to know is if I have the crank ground can I get rod bearings that are .020 oversize? I spoke to one person and they told me that they only come in .010" nothing more, do I have an option for bigger sizes in the rod bearings? Let me know ASAP so I can know if I need a next crank, reason I took the crank in the first place is that it already had the long snout.
Jason
1 - 1 of 1 Posts
