Hi guys!
Need a bit of help. I've had a lovely R32 GTR for a while now and it's an awesome and fun car.
Coming back from my mates house tonight I was heading along a straight road (my mind drifting away) when I suddenly spotted a left turn that I should have took, so I sharply swerved left and turned in, and slightly hit the kerb on the right side at about 20mph (if that) The steering went light and the steering wheel now sits at 45ish degrees to the right.
I panicked and jumped out of the car to look at the damage.....only a slightly kerbed wheel and can't see anything damaged underneath. The only thing I could see is when the steering wheel is straight the N/S wheel is straight but the O/S wheel points in a little bit like so> | \
Driving down the road the car doesn't really pull in any direction but the tires squeal around corners and the HICAS light came on on the motorway, turned the car off and back on and the light hasn't come back on since.
Now I hope I haven't caused any serious damage as I'm skint at the minute, I'm fairly handy with a spanner and can replace the parts myself but I can't see anything wrong underneath?
From what I've described would it be possible to take it to Kwik Fit/ATS etc... and get the tracking done again to fix the problem? or would there be something else bent/broken? track rods? lower arm, steering column etc etc...? Also are the R32 suspension/steering components interchangeble with 32gts/S13 etc...?
Any help/advice much appreciated!
Thank you :wave:
Thank you :wave:
