Welcome. Does it stall when the clutch is pressed in (when coming to a stop)or when your driving?
Mine has done that a few times- any idea what causes it?
^^^^ What he said
3rd that ^^^^^^^ mine cuts out rarely when i dip my clutch
The most common cause is aftermarket bov or air leak some where? I would try using a stock bov too see if that helps and try checking all hoses and clamps for leaks.Me too!! Not fuel pump. Poss afm??
Hi, Have you checked all the connections on the afm? Also have you tried putting the old one back on too see if it starts then? It may be possible that your new one is faulty.hi, i replaced the AFM and now it wont start at all, im at a comlete loss, any help would be greatly appreciated, cheers, lee
