i was told that i would not need the o2 sencer with the decat pipe, the o2 goes right into the catalytic converter and i dont know whether not having it will affect the way that it runs or if it will stop it from running at all... any tips?
the sensor in the cat is not an O2 sensor, your O2 (lambda )sensor is in the turbo elbow
the sensor in the cat is a heat sensor to tell when the cat is over heating, it's not needed in the decat pipe and is best tucked away and cable tied out the way
possibly, but depending what decat you get it should have a screw in area, so it stays connected and working
I had to cut mine off because it was siezed solid into the CAT. Didn't make any difference driving the car and the light doesn't come on. :grinno:
