1 - 3 of 3 Posts
Hi everyone. was wondering how i go about disconecting the hicas on my r32 gtst. i got some locking washers from rk i wanna fit. is it a simple case of disconnecting the hicas ecu on the parcel shelf?
Cheers :cheers:
Omar
I have the Tomei kit installed on mine. It has the locking washers, and a small box that you wire into the HICAS ecu that stops it from trying to adjust the rear wheels.
where do the washers go ? is it between the tierod and the hicas rack itsself ? i was going to do mine this weekend ive got a pump that ive converted to just power steering,i was going to cut a hole in the rear of the hicas rack and weld the pinion solid
1 - 3 of 3 Posts
