I have a 95 GTS-4. I've heard that no GTS-4's were equipped with HICAS, however on the fuse box, one of the fuses is labeled HICAS. While reading through other threads, it seems that cars with the system have a light on the dash that illuminates when the car is started or when something is wrong, I have no such light... What's the easiest way to tell if the car is equipped with HICAS?
Also correct me if I'm wrong, but if I do have HICAS, to disable it I can't just pull the fuse, I'll need lock-out bars? Thanks in advance!
