1996 R33 GTS-T
Hey guys
Im trying to find instructions on how to swap out the door lock cylinders, cant seem to find anything.
Can anyone point me in the right direction?
Im actually planning on swapping out all the locks but already found some info on the ignition cylinder and the boot that look pretty easy but am not certain on whats involved with the doors
It is, I used a ratchet spanner on 1 nut, but that might not of been on the lock. The metal rod lifts straight up out the door lock mechanism, you will know what I mean when you see it.
If your changing locks as the door lock doesn't work with your key, try a spare, I thought my door lock was knackered until I tried the spare, which worked perfect in the door locks.
So heads up, might just be a blunt key and not the lock.
If the original key doesn't work then there is no probability of spare to work with those locks again. So, consider doing replacement of these door locks with the help of a locksmith or a dealer.
