was thinking about buying this and fitting it as one of my coil packs are stuffed has any one used one of these kits?
it say i need a series 1 ingition amp with plug to fit it are they hard to come by?? and how much??
RB20/RB25/RB26 Wasted Spark Remote Coil Pack Kit £145.00 inc VAT
Click to see more
A common problem on the RB series engines is the coil packs degrading over time due to heat and age. The standard coil-on-plug setup is sensitive to heat, combine that with them located on one of the hottest points of the engine and you can see where the problem comes from.
This DW Wasted Spark kit comes with a 6 cylinder coil pack that can be located anywhere in the engine bay. This allows you to place it away from any heat sources, so it won't break down over time like the standard coil on plug setup. Added benefits of this setup include the ability to change spark plugs much quicker, simply requiring the HT lead to be disconnected and then the plug is accessable.
To work further towards a strong ignition system, the included 6 pole, 3 channel coil pack runs a wasted spark setup. This ensures a good, strong spark allowing all fuel to be burned efficiently.
The kit includes 6 specific length 8.5mm magnetic core HT leads capable of handling 85,000 volts and 300 degrees C, 6 pole 3 channel coil pack, wiring kit, fitting hardware and full instructions.
Fits RB20DET, RB26DETT, RB25DET Series 1, and RB25 Series 2 by retrofitting an ignition amplifier from one of the above models (please enquire for more details).
Competition proven!! As used on both Driftworks R32 Skylines!!
Click to see more
