1 - 2 of 2 Posts
car is a 2002 e46 330ci sport in topaz blue
102'000 miles
mot feb 2021
brief costs attached of what ive spent on it
safety devices 330 challenge spec roll cage and rear strut brace-£2000
sparco circuit LF 2 seat (the big one)-£450
has passenger seat and belts fitted but easily removable
safety devices 6 point harnesses-£130
powerflex black series bushes front and rear-£450
vibretec engine mounts£300
oe replacement gearbox mounts-£40
330 challenge quaife atb rear diff with new bearings and seals fitted at same time-£1500
330 challenge tvv lightend flywheel and clutch-£800
twin fuel pump set up (gauge still reads true)
330 challenge ram air induction kit-£60
330 challenge klarius downpipe back exhaust system with removable silencer bypass pipe-£450
330 challenge poly rear window kit-£409
flocked dashboard-£100
rear subframe reinforcement kit-£150
rear subframe powder coated-£100
lightweight battery (recently replaced)-£130
plumbed in fire extinguisher kit with external pull cable-£250
battery cut-off with external pull cable-£50
tegiwa m3 cup rear spoiler-£350
tegiwa m3 cup front canards-£100
tegiwa m3 cup front splitter(made from plywood) still have the template tho-£100
2xfront and 2x rear wire rope tow straps-£50
carbon fibre effect front sunstrip
mcgill motorsport quick release steering wheel boss-£100
alloy radiator, thermostat, water pump and header tank replaced at same time-£300
air con removed
wiring stripped back
remapped ecu-£250
labour for roll cage and rear subframe reinforcement-£2200
all the car really needs to finish is a set of suitable suspension (currently on standard shocks with eibach springs) a set of tyres and bonnet pins fitted(have aero catches that ill throw in)
i do have some extra mv1 18" alloy wheels, a set of ds 2500 front pads and eibach rear camber arms which are not fitted but may be available if there's interest
prob more that ive forgotten but please ask if any questions
located in fort William in the north of scotland
may be able to help with delivery
1 - 2 of 2 Posts
