ive done a seach and looked at the manual and i think im being thick,lol
it says in the apexi avcr manual to join:
1. red = power
2. purple = rpm
3. green = ground
4. black = ground
5. gray = throttle
6. white = speed sensor
but i cant seem to find what numbers on the ecu to splice them into, i know 2.purple = rpm has got to be pin 7
6. white = speed signal has got to be pin 53
but what pins do the rest splice into???
any one shed some light on this??
ecu pin out : r33 gts-t rb25det ecu
Space Filler
There should be 2 manuals with it. One has the wiring blocks for the ecu's of most of the common jap cars.
I think you can download it from the Apexi site if you didn't get it with yours.
cheers cossiedave but im now confused i have a apexi diagram ecu chart for the safc2 and the pins are in different places to the manaul i have??
can any one who has a already plubed in avcr have a quick look for me?
its just the earth thats differnt. one says - 60 is ground the other says 50??
rest seems the same
just had a quick look on net and this is what i recon mate
pin 101 injector
pin7 rpm
pin 38 throttle
pin 59 +12 v
pin50 ground
pin 53 speed
dont take these as gospel mate just trying to help you out but doudle check em before you wire it up and make sure you disconnect your earth off tyour battery
http://paulr33.skylinesaustralia.com/diagrams/Apexi_AVC-R_wiring_manual.pdf
Space Filler
When I was wiring mine, I drew a line to each pin on the diagram and marked what it was for, then crossed each off in turn as I soldered them. made it a bit easier to keep track of them.
Although annoyingly a week later I discovered on RHDJapan a wiring loom extender that goes between the loom and ecu to let you wire stuff in without touching the original loom. D'oh.
