My BNR32 GTR all of a sudden started making a strange noise by the firewall & Intake Plenum , my radio started going on and off,warning lights went on/off and the charging system went to the max. I shut the car down and popped the hood and noticed the battery was boiling.
I changed the battery and still the same problem? Could this be a short somewhere? Thanks.......
check ur alternater as it sounds like it is massively overcharging the battery and dont start or drive it as you can do serious damage to your car mate.
North Wales Area Rep
my 2p's worth,sounds like the voltage regulator thingemy on the alternator,you are lucky it didnt go bang fella. Had it happen to me once and it scared the bejesus out of me,dove in a water tank to wash it off n 2 hours later my top was full of holes.
Boiling battery is not good Squirrel. I pulled out the alternator today and just dropped it off at the shop, find out in the morning if thats the problem. Cheers......
Yep......that was the problem. Having it rebuilt and pick up in the morning.
Thanks for the help.......:cheers:
