I need a map for the emanage ulitmate airflow output map so that i can eliminate the afm. if anyone has one that they can send to me on a excel or anything like that i would appreciate it.
i have hooked up the greddy pressure sensor to the emanage now but still cant get the car to run right with the maf dissconnected. is there anyway to get the emanage to read off the pressure sensor and not the maf. i would really like to eliminate it if possible. thanks
I think your best bet is to have a word with one of the tuners on here, they may be in a better position to help as I am not sure how many people use the ultimate set up at the moment.
If you want to do away with the AFM you need to use it first to create a Airflow adjustment map. You need to datalog the AFM outputs and put the values into it. You will then be able to remove it and run of the pressure sensor.
