1 - 2 of 2 Posts
Discussion Starter #1 (Edited by Moderator)
lost my drain plug as on second run water was too hot and i under estimated it .
any idea what type it is so i can get a replacement ?
does anyone know bolt size for cylinder drain bolt ?
mine gone missing
The one just below the turbo water feed? It's 1/4" BSPT (tapered thread). I used the hole to feed water for my DE to DET conversion and that was the size fitting that worked. If you need to specify length to buy one let me know and I'll measure my old one.
1 - 2 of 2 Posts
