1 - 18 of 18 Posts
Hi.got a problem,the engine breather kicking oil into the oil can catch.I run 3 times 1/4 mile and got about 1 inch oil in the can.why????for example if i will run 10 times the can will be not enough to catch kicking oil.what to do ???
Forum loiterer!
i dont want to sound fatalistic (sp) but i have seen this problem a few times when one of the pistons has dropped a ring. doesnt mean this is the problem but its a possibility
pop the spark plugs out and check them for oil fouling, remembering which one came from where so you know which maybe the problem
I hope it's not a piston mate, it will be an epensive job. Do a compression test and get back for more info
Paul
Discussion Starter · #5 ·
i did compresion test and i 'v got 7.5-7.7 bar on all six cylinder.hope it s good.
Discussion Starter · #7 ·
oil presure when start engine goes up to 5.5 an then after 4-5 min 3.5bar on 1000revs.My maximum revs goes on red line up to 7000 but when rev more then 6ooo the engine kicking oil via breather badly,i run 3 times 1/4 mile and got 1inch in can.
Discussion Starter · #9 ·
iv got 15w 40 mineral one,not very good but top polish one.i think it s not the oil but i wish u right
when i ran it on fully syn mobil one it used to breathe a bit heavy and drink it so i opted for a slightly thicker semi syn and it didnt breathe as bad so i was just thinking if he has a bit off wear and his oil is past its sell bye date it would be the first and cheapest option i would take , taking his compression is pretty even on all cylinders and no plugs are fowling, has he got any back pressure coming up through dip stick?
i would double check and do a leak test. somtimes a compression test will not show any bad signs.
I´m not a specialist, but as far as I know 7bar compression is too low! Did compression tests on other skylines and had about 10bar (+/- 1bar). Don´t wanna worry you mate, just a thought. Sure someone will correct me if I´m wrong...?!
7 bar is way too low.
also, a compression test will not always show leaky rings.
I had about 10 bar compression on all 6, but had also done a leakdown test, that yielded 4,5%, 4,5%, 8%, 12%, 9% and 4,5% .
spraying oil out of the breather...
Discussion Starter · #18 · (Edited)
my skyline has 67.000 mile on the clock so a do not think so cylinders or pistoness gone,in it.i do not know what to do but will put oil can catch to keep oil.
Maybe valves rings????
1 - 18 of 18 Posts
