bolts straight on just remove the front drives, plate the holes in the sump, job done
half correct, yes it does mate, but unless the sump has been modified for a gtst then the subframe will get in the way and the oil will pour out of the holes for the drives, you need to cut the diff casing off the RB26 sump and weld in a new piece althogether making sure to leave enough room for decent amount of oil but not so much that it wont fit also.
drives??? its a rb25de at the moment but been offered a rb26dett , what holes where in the rb26 is that
