1 - 10 of 10 Posts
what needs uprating to run or get 350-400bhp
i have:
fmic,walbro,airfilter,3" downpipe back
getting... sfac2,t3 cosworth turbo..
any think else needed?
when will these bits need uprateing :
clutch
head gasket
injectors
cams
is there any think else that is needed?
head gasket should be ok for that sort of power as will all the rest of the internals
you will also need a Z32 AFM as the standard one max's out around 350hp
your SAFC2 should be ok but i would consider getting an Apexi power FC
and you can add a turbo elbow to your list aswell
AKA RSP
I would go for a Hybrid rebuild of the standard turbo, Boost controler, Injectors, AFM (depending on ECU), Clutch and PFC or Emanage ultimate.
The SAFC will not give enough control to make a safe 350-400 as you have little/no control over ignition.
Richard
ive been reading a load of previous threads on this forum that have gone to emanage due to the pfc`s price and they were discontied but if the price was droped im sure most of them would go for the pfc, can you make a new thread were its visable to see there is a group buy to test the water to see how many ppl are willing to take this option.
if there were in my price range ill be up for haveing one with mapping done.
the mapping may be a good idear if every one was local but dout alot of ppl will traval unless there was a Rolling road day included.
hope this helps
1 - 10 of 10 Posts
