engine number is down low on the engine, exhaust side, a tad to the firewall
if you look at the engine from above standing on the passenger side then peek just right to the tubby and try looking all the way down, you prolly wont be able to see it that way but it is there :dogpile:
i found mine from underneath with a lamp and little mirror, to be able to read it i had to rub it a bit with some sanding paper
hope this helps you out
