1 - 11 of 11 Posts
Thats button by the headlamp level adjuster, the light (or LED has gone, it still works cos i can hear it, but the light on it has gone. Is there a seperate fuse to it?? or how can i check its the actual light inside the switch is blown??
regards
J
Discussion Starter · #7 ·
Nick. it should. cos i have seen it working.... I want a proper job so i need to get that working as well as re-wire it to the fog light/.
I am assuming then that mine has been replaced by SVA UK to one without the illumination for the fog light.
Gets Blown by Twins :D
Mines a Fog light switch and it has an LED which lights up on it.
Joe - My guess is that the LED has blown and they're not meant to be replaceable. You could buy another switch from Halfords etc for a couple of quid and rewire it (if it's not soldered then it should be fairly easy)
1 - 11 of 11 Posts
