i just installed the garret GT2510 this past weekend, and we didn't have any of the oil lines, any of the coolant lines, or the compressor outlet flange. so we went into our garage and scrounged together a bunch of adapters and hoses to make all the lines. then i cut my old smic pipes to create the compresor outlet flange. i also installed one of those ebay stainless steal manifolds, then we put it all together and started it up... well im leaking exhaust between the manifold and the head.
i have 3 studs on the top section that sheered into the block, and 2 on the botton that sheared off. but before u say thats the reason y im leaking exhaust, i had my car running like that after i installed the rb25 turbo and had it set at 1.3 bar for about 8 months with no probs. but after i installed all this, you can hear a faint exhaust leak on the first or second cylinder and it gets really loud wen u stomp on the throttle.
well whats the best way to fix this and how much would i have to spend? if i have to replace the head, how much would it all cost in the end?
thanks!
thanks!
