1 - 3 of 3 Posts
failing that some part numbers would be good...
Just basic things too....
Oil Filter - I know a micra one is used but which one as there seems to be different ones...
rocker cover gaskets....
Fuel filter... (is there a performance/larger/higher filtration one available?)
The rubber mounts used on the radiator mounts.....
If possible some high pressure stainless steel braided hose for fuel.... 8mm I believe it is....
And for curiosity or if anyone has them lying around.. some uprated/thicker anti roll bars front and back for an r33 gts-t
oil filter from nissan A5208-H8903
you may be able to use a fuel filter from them too.
1 - 3 of 3 Posts
