1 - 2 of 2 Posts
skyline nut
hi there guys i have been doin a top mount set up on my gtst for the last 6months and today i managed to get it running. i got a few lil probs to sort out but the main thing i need to do is set my TPS can anyone tell me how to check the voltage and also wot the voltage should be set to. it is a q45 TB and TPS by the way.
if any one can help it would be great
cheers dan
AKA RSP
How easy it is to setup will depend on what equipment or ecu you have.
If you have a standard ecu the easiest way to set it is to connect a laptop to it and check the voltage.
If you have a PFC with a hand controler you can see the voltages in the sensor screen.
If none of the above is possible use a multimeter on the output pin on the sensor. (I can not remember which pin but one is a earth, one is voltage in and the other is out.
You should be looking to set it too 0.35v - 0.45v.
Richard
1 - 2 of 2 Posts
