firstly big thanks to shawny, the exhaust is mega.
fitted an induction kit this weekend, then shawnys exhaust turned up on my doorstep after some very technical logistic planning lol - induction kit went on pretty easy with no real probs and sounds great, give the engine sound that little bit of edge.
so got the exhaust on pretty quickly with no major dramas, apart from that it is about 2 inches short lol , it now sits flush with the bumper (inset a teeny bit), think this is because mine is a 4 door so that little bit longer, however not a problem that a hacksaw and a metal protective plate cant fix (looks pretty good aswell lol), not as loud as i thought it was gonna be however not sure if that got anything to do with mine being SOHC, but it gives a lovely purr and starts to roar over 3000 rpm, really sounds sweet
so in all im very happy with my first couple of mods wooo hoooo, and im learning as i go along, which is great.
next is wheels im on the look out for 17inch 4x114.3, if you got any you wanna get rid of pm me and ill gladly take them off your hands, - thats all for now - pics will be up very soon
kindest regards,
fitzy
Top fella
Great to hear it went on all ok , a decat mite make it louder as when it was on mine it was LOUD . Good luck with the rest on your project mate and if you need any info and i can help just give me a call
Cheers Shawny :cheers:
Nice one! :)
I guess no problems unbolting the original exhaust from the cat, or did you replace the cat as well?
I'm slightly reluctant to do mine cos I keep hearing its quite likely to sheer the bolts off the cat which would leave me a bit stuck. Just have a drill ready and some replacement bolts+nuts just in case I suppose.
Good job :bigthumb:
yeah the bolts where stuck , prob cos of the heat that goes through over time has just siezed on there, but i just used a socket set and went for it lol, even pressure on the nut instead of forcing it in one crack, took quiete alot of force lol, was gonna give up at one point and nip up to ATS just to get them to crack the nuts but brute force and ignorance did it in the end lol the exhaust from the cat back is only the two bolts and the new one fitted on like a glove, the original seal was still ok so just put some gum gum paste on and bobs your uncle, prob took about 40 mins to get the exhaust off mainly cos of the rubber hanging brackets but just used WD40 on them and they slipped off with a bit of force, then the new one was on within 10 - 15 mins pretty simple and easy to do really - i used my own ramps (from halfrauds), think im gonna get the cat took off in the not so distant future but for now its much better, and coupled with the induction kit sounds 100 times better lol - good luck with yours, if you need any help just pm mate
wicked, cheers for the info. I'll spray some Plus-Gas on them first see if that helps with a normal socket set and then try with an impact gun if they don't come unstuck (I have weedy arms! :) ) I've heard impact guns can sheer bolts but I think that is more when tightening and over torquing. What's the worst that could happen lol.
Hope you are enjoying your exhaust!
