1 - 8 of 8 Posts
bought this last night. If i fit this to my r33 gtst what do i do about my std bov
how do i get rid of it? or do i just leave it as it is????
please help what do i do????
will i need to buy a hard pipe to suit this so it can be mounted ok
or should i be able to make my own one do with some mods
Just leave it mate... I ran them both on mine and had no probs... Just double the noise...
Get some metal an cut it to the same shape as to where it bolts on to the inlet pipe, put this bit of metal imbertween the dump valve and the pipe it bolts to, this will block it off, then you need to block off the other pipe that goes back into the pipe just behind the air filter, you can get a rubber bung from BnQ that normally goes on the leg of a stool, so iv heard!
Or yeah, leave it! I did for a while aswell, decided to block it off in the end though, did my head in!
If you still have the stock intercooler piping, you should be able to pick up a 33 hard pipe for it second hand(Driftworks or eBay usually see a few go through). Don't think you can buy them seperate brand new.
But you can buy the weld on flanges:
http://www.blitz-uk.co.uk/Product-182.aspx
Have mine in the shed ;)
Blank the recirc of and remove the pipes.
1 - 8 of 8 Posts
