1 - 17 of 17 Posts
guys,
mine makes a woosh sound as the car revs up, I think it's the
wastegate (not sure) but definately not a BOV!!
How difficult is it to fit a BOV to an R33, and what's a good
BOV for a Skyline??
Fitting a BOV
I have fitted a HKS SQV (Super Sequential Blow Off) to my GTS it took about 15 minutes you just need 1 spanner. The sound is totally different it’s a kind of whoosh and whistle noise, you should be able to notice the difference straight away.
Simon
BOV
The stock BOV you don't have one yours is a re-circulating valve. This should be located just before the throttle body on the top of the engine facing to the rear, with a 1½” pipe going in from the right and a thin pipe connecting it to the inlet manifold on the left.
I hope this helps.
Discussion Starter · #5 ·
Thks Simon,
I'm gonna have a look later:D , would good if you don't need
any major pipework
any recommendations for waht works on a Skyline: I had a TurboXS in my 2nd Pulsar and it was good, but the best BOV I
ever had or have heardwas a Sheepdog BOV that I had in my 1st
Pulsar, I should have kept it!!!!!!!!!
Discussion Starter · #6 ·
found the stock valve, doh, can't beleive I couldn't find it earlier!!
anyway noticed the way the stock valve is positioned is class!!,
no welding or messing about with T pieces and tubing eh!!
have ordered a Turbosmart Supersonic BOV + adaptor that will bolt straight on:) , plus a Turbosmart boost controller to raise
boost to 1 bar:)
car should absolutely fly & sound the dogs by next week:D
If its dumping to atmosphere you may get stalling at idle, cos the AFM gets confused, might need an add on bit to sort it out.
Discussion Starter · #8 ·
yeah have heard about that, roughly understand why, but hopefully the BOV i've ordered doesn't do that.
if it does, what do I need to add on??
In theory, any dump to atmo valve on a car with an AFM has the possibility of confusing the ECU. Theory often means nothing in the car tuning world however and most cars with AFMs' don't report any problems at all, at least if using a 'proper' dump valve.
By 'proper' I mean one that won't open on idle. Theres absolutely no way on Gods earth you will open an HKS SQV on idle so thats a good start. This doesn't mean you can't still get problems because you will still be dumping air on the overrun, and in those cases an HKS EIDS (electronic idle stabiliser) is required as Buster says. They are not fitted as a matter of course as relatively few cars show any problems, but it's there if you need it.
I have no idea how the Turbosmart valve works but if it opens on idle or uses some crude method to prevent it doing so, either by using a overly stiff spring/various bleed valve devices or any other air-route method then walk away and just buy a proper valve instead.
Cheers,
Nathan
TDI PLC
PS....Buster......is that you? Looking to go to the USA? There can't be 2 people under the name of Buster going around in white R33 GTS's can there..?!
Cheers,
Nathan
TDI PLC
Nathan, What have I missed mate, I dont even understand that USA caravan post let alone wanna go, or is it something else you are refering to?
Discussion Starter · #13 ·
Thks Guys,
I think I should be ok, the Turbosmart BOV I chose is real quality,
these guys only specialise in Turbo acessories and have done
so for over 20 years, it's just that thy are based in Oz!!
If you go on the website you get an excellent chart which recommends the most suitable BOV's & associated adaptor & or
fitting kit for your car - superb:D (www.turbosmart.au)
No offence but i've tried a HKS SSQV and whilst it looks great it
doesn't give that nice woosh on throttle lifts. Whilst HKS are one
of the top people for engine internals I do not rate their BOV's, I
think they are over complicated, pricey & overated - just my opinion;)
Sorry pal, must be someone else! We have a customer, with a white R33 GTS-t, goes by the name of Buster and is in his late 40's/early 50's. I saw the text under your avatar and put 2 and 2 together! Whats the odds of that?! He is emigrating to the US soon so thats why I asked.
R33 Type M: No worries. You pays yer money!
Over complicated? Well, I've rarely seen one fail. Also, they are only as complicated as they need to be.
Pricey? It's a relative term. Against £50 'diaphragm' type jobbies they would be I guess...
Over-rated? They do what they say on the tin. Not sure how they could be!
Anyway, like I said it's no problem. Life would be boring if we all did everything the same!
Cheers,
Nathan
TDI PLC
Nathan. Thats it give a girls age away :mad: Still gets you cheap insurance. :D I try to stick to one maker of parts when I spend dosh on my motor so I would probably go the HKS route, also reputation and having "heard of em".
R33 you will have to give us the low down and some pics when its fitted, never too old to learn.:rolleyes:
Nick
Discussion Starter · #17 ·
Nick / Nathan,
Yip it's always easy to go witha big name, I just know that these
guys have a big following in Oz & so must be good:)
Price wasn't important to me, it cost £160.87 from AET Turbo's,
who are the distributors for the UK, will definately get some
pics and vids of how it sounds when it's all done. It is supposed
to sound awesome!!, we shall see:D
Thks
Lee
1 - 17 of 17 Posts
