I'm trying to fit a leather armrest cover and after a couple of hours have finally lost my patience! I’ve been using brown tape to pull the sides straight so I can get the seam to run straight and in the middle of the curve of the rest. I get about 90% of the way there but it looks a bit amateurish.
The cover it self is a pretty good fit, it’s just getting the tension distributed evenly I think. Thought about using some contact adhesive, but this doesn’t give much manoeuvring once the cover is fitted…
Anyone got any tips?
R33 GTS25
I assume you've unscrewed the cover on the underside of the armrest and are using it to secure the leather to the cover?
That's the intention! I'm trying to get the seam to line up on the length of edge of the armrest (it’s a curve not a 90 degree corner) and also the width, so there are 4 straight parallel lines on all sides when viewed from above and without any noticeable creasing to the leather.
It's a damn sight harder than I first imagined it would be and I’m frankly beginning to whish I hadn’t bothered as suddenly (and by no probable coincidence) the OEM rubber effort is starting to look a lot more appealing!!
Maybe a rubber fetish is better to have than a leather fetish after all…
R33 GTS25
OK. I sort of screwed the underside cover half-way back on, then used a dull butter knife to press the leather (alcantara in my case) into the space beneath the underside cover.
This way I could adjust the trim as I went along.
(Sorry if this doesn't make any sense, I've spent the night in a pub. ;) )
