Been meaning to fit some 'new' (second hand) 'speakers in the car, finally got round to starting today.
Sadly the new ones (Kicker R6) don't fit in the standard plastic housings; too deep. So, I hacked away the rear bit only to find that the screw holes don't line up at all and there's no way to frig it.
Still, at least it forces me to 'do it properly'. Now, I am a bit cack-handed so please don't rip into me for the quality of the work!
The first step should be to remove all the plastic from the rear of the original housing, so you can use this as a template...
I only did this after making the MDF parts; should've done it earlier.
I have no idea how much clearance there is behind the 'speaker hole, so I've guessed that two layers of MDF will provide enough:
All joints are glued and screwed, and I made some cable holes in the 'partition' bit so that I can mount my cross-over in the door card pocket (this should not be necessary on the passenger side as it should be able to go the other side of the partition bit):
Edit - I didn't bother doing this for the cross-overs in the end, see part two...
Gave them a bit of spray paint which may help them to resist moisture:
And that's it so far - I haven't offered it up yet, so I'm hoping it will fit!
I'll post more when I've got further... :disappointed:
(edit - see part 2)
(edit - see part 2)
