1 - 10 of 10 Posts
It would be cheaper to buy an aftermarket lightened flywheel than buy new at Nissan
Or put a wanted thread up for a good used one.
You might need to get it skimmed though, so new aftermarket or new Nissan might end up cheaper in the end depending on how much the total will be.
Oh there is a difference between turbo / non turbo flywheels. The turbo flywheel has a 9 bolt pattern for the pressure plate and I think its 1/2" wider.
Non turbo flywheel has 6 bolts for the pressure plate.
If you are upgrading your clutch at the same time I would recommend the turbo flywheel as it gives you better upgrade options for clutches!
thanks for the suggestion i really don't need an upgrade it is a non-turbo and i just need something to put on there thats new cause here they don't turn down flywheels also it's just going to be a daily driver and maybe take to the nurmburgring maybe lol
1 - 10 of 10 Posts
