i would replace it rather than weld,the little bits around the hole look like they would have been where that hole is now,no idea how you could have got it hot enough to do that though,must have had a small pinhole in the metal
Im thinking of getting an external wastegate havent decided yet money is tight, but what I meant was replacing the dump pipe with one of theseLooks loke someone had fitted another sensor there and removed it and the weld didn't hold or they didn't do it properly.
New one definately.
Don't go screamer unless you've got the external wastegate to fit it to.
Looks like that , abit too round to be caused by anything else.Looks loke someone had fitted another sensor there and removed it and the weld didn't hold or they didn't do it properly.
New one definately.
sweeeet will send u pm!Ive got a speare rb20/rb25 factory downpipe bro if you want to buy it off me cheap man... hit me up
Thanks for the advice!Looks like that , abit too round to be caused by anything else.
Those screamer pipes can be hard to seal right, usually sound like a tractor on tick over.
You'd pick up a stock rb25det elbow for a few $$ ,will do the job :bigthumb:
Thanks mate but will need it by Tuesday dont think that will be possible!I had this exact screamer pipe and it didn't seal correctly and the waste gate penny got stuck all the time, I removed it but two of the bolts snapped and I ended up getting another turbo,
I have a standard elbow down the garage you can have for free if you pay for postage bud, the std item is fine for 400 bhp at least, I only opted for a HKS item as I replace the turbo anyway, the screamers do sound like a blowing tractor if they are not sealed correctly.
matt
